Hi all,
I have a 1996 Mercruiser 7.4 Bravo 3 with a 4bbl Weber carb. This engine is very hard to start after it sets for a few days. It will crank and crank but not fire. I can pump it forever with no luck. Eventually, after lots of cranking, it will start. If I pour gas down the carb, it will fire immediately. The choke is closed and adjusted properly. It's like the float bowl empties after it sits for a while, and it takes a while for the fuel pump to fill it up again. (Like the infamous Quadrajet problem) Either that, or the accelerator pump is toast. ( I didn't have another warm body to check for fuel squirts) I have no experience with Webers, so I'm looking for opinions.
PS $120 for a rebuild kit? Whoa!
Bodean
Bodean
