Re: Tips on cutting up a deer
Venison is the beef in our diet. We shoot some, get given some, and even pick up fresh road kills if we can. One of the best was a pretty good sized buck that totaled a durango at highway speed. The side that was hit was tender, but the impact sheared the heart right off, and there was no blood in the meat. It was all in the cavity.
On aging the meat. Classic aging if you kill, skin, and get it in the cooler right away is 14 days at 34 degrees. It takes about 3 days at 43 degrees. With experience you can usually tell when it's right. Aging tenderizes the meat. A young animal really doesn't need it, just cooling and draining the excess blood.
I de-bone the entire deer. As stated before, sort out the muscle groups in the hind quarters, and cut them cross grain into steaks. You can also use bigger hunks as roasts. Whatever comes out goofy goes into the hamburger and stew meat bowl.
The front quarters all go into hamburger or stew.
The back strap gets filleted off in a strip and cut into steaks. Lower back is sirloin, upper back is strip steaks.
Inside the lower back is a pair of muscles that is absolutely the best piece of meat in the animal. It would be fillet mignon in a beef. We usually chicken fry these little steak morsels and serve them to company. They melt in yer mouth.
Everything else gets cut off the bones and goes into hamburger.
The hamburger gets completely de-fatted and cut into small pieces so it will go through the grinder. We then spread the pieces on cookie sheets and freeze them. Then we put them into zip-locks and save them till we get time to grind. We have a belt driven grinder that will do about 60 lbs an hour, so usually it's several deer at once. When we grind the venison, it has no fat in it, so we mix in 10% beef fat the local butcher trims off steaks and roasts. It is very delicious any way you cook it.
As stated before, venison fat does not taste good. Trim it all off, and replace it with any other fat from bacon to butter to beef fat.
The thick pieces of back fat get saved and frozen, to be put into onion bags and hung out for the chicadees and woodpeckers.
The carcasses get hung up in trees in the back yard. The chicadees, woodpeckers, and nuthatches will pick on them all winter.
All the other trimmings and fat get frozen in small packages for dog and cat food. Anything that might have lead in it is carefully trashed. (I've gone to an all copper slug.)
Hope it helps
John
