Re: Ethanol
silvertip
I gotta disagree with ya on this E stuff.
it does affect the dip tubes in the red poly tanks, faster if the tank is exposed to sunlight.
the clear poly tanks when exposed to sunlight will start dissolving and dip tubes dissolve and fuel sender floats start dissolving.
all issues we have fought here in the salt pond since june of 08 when we first got suckered.
quite a bit of the 500 plus boats sitting on the yard tend to have owners 100 to 1000+ miles away.
the boats tend to sit, a lot.
stabil when treating FRESH fuel tends to last 5 or 6 months max.
and with a laptop or a handheld you can see it on most modern sterndrives and inboards with MPI motors ,look at the knock retard numbers or the octane derate numbers the ECU is outputting.
the E 10 fuels by themselves are not the issue with most engines post 1992, it the sudden shock of the varnish built up in the hull systems thats killing things.
older engines we are seeing more and more crank seal failures due to the rubber not being ethanol compliant.
most vehicles have sealed fuel vents and very few stay parked in a permannant mud puddle.
there is not a marine engine offered for the general US market that can run on concentrations higher than 10% ethanol.
my 08 ranger wont and it hates e 10.
E10 for marine and industrial applications is simply foolish but as its mix at the tanker distribution terminal you wont see many stations with E free fuels.
