erikgreen
- Jan 8, 2007
- 3,105
Re: Winter refit - transom
Okay... no pics yet, but picture the interior of a boat's transom, with an I/O drive hole, with about half the wet wood pulled out.
The largest piece so far is about 6x6 inches.. the ends are less rotten now that I'm getting to them, so they're harder to get out. I'm glad the outer skin is so tough, otherwise I would have punched through with the pry bar a couple times.
I got a set of pry bars from harbor freight for $8 and they've helped a lot... having two bars lets you "walk" a crack larger to peel up wood.
I stopped at a local glass place that redfury pointed out to me yesterday at lunch time. I got a vacuum fitting, a little gelcoat, and some flow media.
If I can put together a vacuum reservoir/overflow canister tonight I'm basically ready to laminate in a vacuum bag, although I still need a vacuum switch. I'm thinking I'll laminate the transom with glue by hand, then when it's cured I'll laminate 3 or so layers of 8 oz cloth (I have a lot of it) over the forward side under vacuum. Then I just need to tab it in place when I install it in the boat.
If that works I'm thinking I'll do the same with the other structural parts I put in this winter... cut to shape, fit, then vacuum laminate, then put 'em into place and tab. Might be a lot easier than working on vertical surfaces in the boat.
Erik
Erik
