81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
bankfisher
Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
Is it in yet???
Is it in yet??
How much longer??:D:D:D
Looks great Frisco!! I'm sure everything will work out fine.
Do you think the 75-90lbs of water pressure from your house piping could have just held the tstat open??
clockwatcher
Do you think the cam is broke in completely?
Also, have you thought about installing an oil drain hose? I like the idea of draining the oil without having to pull it through the dip stick.
Friscoboater
No I do not think the cam is broken in right. I just hope I have not done any damage. Being that I do not have a very aggressive cam profile, I hope it will be ok.
I plan on installing it this weekend as long as the weather holds out.
BobsGlasstream
Hey friscoboater,
I hope everything goes as planned. Perhaps Murphy will leave us both alone this week.
Have you started mounting the transom assembly yet?
Good luck, I'll be looking forward to the pic's.
Bob
Friscoboater
Clockwatcher, I thought about the drain hose but no one has one in stock right now. I have goo access around my oil pan to add one later.
Bob,
I just installed the transom assembly and did my gimbal bearing to day. The plan is to drop the engine in this weekend. I will have some video and pictures up in a bit.
BobsGlasstream
Hey frisco,
Sounds good, I'll be waiting on the pic's.
Bob
Friscoboater
Here is some video
http://www.youtube.com/watch?v=IuPWTqObTNA
BobsGlasstream
Hey frisco,
Looks great.
Quick question, did you buy the puller or did Autozone let you use it?
I think you'll be glad you stayed with the standard exhaust.
Bob
Friscoboater
I did their free rental program. They charge you for the tool and then when you bring it back you get your money back. Pretty cool.
BobsGlasstream
Thanks man,
I'll be checking that out tomorrow. We are rebuilding Robs transom assembly and that would come in handy.
Thanks again
Bob
dorelse
Jay - Did you have a gasket that went between the exhaust y-pipe & the outlet through the transom?
I think mine was leaking through there, and there wasn't one...and for what its worth, that foam gasket is a PIA...I can see it in my near future!
Friscoboater
There are three little rubber o-rings that go between the two. I got some new ones at my local boat house.
archbuilder
Hey Frisco looks great....I have some catching up too do! Can't wait to see her on the water this summer!
BobsGlasstream
Hey friscoboater,
I hit Rob and I hit AutoZone tonight and they had the puller. It made life a lot easier, Thanks for the tip.
I had the same problem on the foam seal. Kinda like fighting with snakes or that game at the fair with the gofers. You get it in at one place and it pops out at another, What a PIA.
Great Job
Bob
Friscoboater
I have a conundrum. I had planned on installing the engine tomorrow but it is supposed to storm tonight and then snow in the late afternoon or evening. We will then have a couple of days of temps that are right at freezing for the next couple of days.
My two options.
1. Drain the block, and manifolds of any water and see if I can get it installed before it gets too cold.
2. just wait until next weekend and loose another week of tuning.
Utahboatnut
since the engine is out now I would just drain it seems like it would be pretty easy to do out of the boat. Then you could get it installed and work on wireing, or any of the other to do's until it warms back up and you can run it again.
Friscoboater
I spoke with my Dad and I think we are going to try and get this done this afternoon. It is supposed to be 70 degrees today and it will not take that long.
vegasphotoman
Hey Frisco....
looking excellent! hey man its startinig to warm up...before ya know it will be summer YEA! anyways....rock on!
tinkeringwackyone
looking good frisco, soon you'll be sitting behind the wheel, on the trailer, with the engine running, fan blowing in your face, pretending your on the lake:D
Can't wait to see the beast installed.
Friscoboater
Thanks guys.
This engine is installed!!!!!!!!!!!!!!!!!!!!!
Pics and video in about an hour!
