cvtech1
- Aug 16, 2009
- 277
I just recently bought a 1977 Glastron SSV 176 with a 1977 140hp outboard. I have been out several times, 4+ and have not figured out the best starting procedure for the motor, sometimes it starts right up when its cold or when it hot. Other times I lift the throttle push the choke lift the throttle pump the bulb push the choke and turn the key lift the throttle etc. It has always started and ran fine to me after several attempts. Does anyone know the best starting procedure for this motor or is there something wrong that I don't know about. It runs @ 30-35 with four adults on it with no problems. Any advice on starting is needed, thanks.
