I've searched iboats and can't find this problem anywhere else so I'm hoping to get some help. I have a 98 3.0 Mercruiser and there is oil bubbling up in one spot between the head and the manifold. It is under the back side of the carb. There is a small indetion in the block casting and oil recently started bubbling up. I kept finding oil in my bilge. There is no water in my oil so I'm pretty sure the block isn't cracked, it just appears to be lealing through the gasket. Anybody else had this problem? Am I missing a bigger problem? The motor has also been running slightly hot recently - not sure if it's connected to the oil problem. Any help would be appreciated!
