KewlBird
- Oct 6, 2007
- 247
Well here is my dilemma, every time I attempt to do a cold start on my 1990 230hp 5.0LX mercruiser I have a hard time!!! The carb. is a 4-barrel Rochester. I will just about kill the battery every time before it starts. I have replaced plugs/cap/rotor and it did not change anything. I tried pumping the throttle 7-8 times and still nothing. The only way it will start with everything connected is if I pry open the choke and crank for a while. If I disconnect the throttle linkage and open up the throttle, it will start a lot easier. I tried adjusting the idle speed and set it to about 800rpms, but its starting is still the same. I also cleaned the carb. and not much has changed except it's idling a little higher. Once it warms up, it will restart without any problems.
My first thought was that engine was cranking too slow, but after checking a few videos my engine appears to spin at the same speed. If I could manually open carb. while starting with the speed/shift control I believe it would start fine. I don't believe there is a way of doing this besides getting new controls. The control on it is factory "US Marine" controller with Tilt/trim buttons on it. I had an 70hp Evinrude that had a "warm up" lever, which opened up the carb a bit which would be a nice thing to have on this setup. So, does anyone have any suggestions?, It's kind of embarrassing to hold everyone up at the boat launch....
