I have a 89 Johnson 15 h.p. that I bought for a kicker motor. The motor will start & run if you choke it but when you take it off choke it will fall flat like it's not getting fuel.
When I got the motor the top cover on the carb that houses the idle adjustment had a crack in it. I figured this was the problem so I replaced the cover and tore the carb apart, cleaned it and put everything back together. It still acts the same. My thinking is it isn't getting enough fuel or it is sucking air from somewhere. Do you think it could be a fuel pump?
