I have a Sears J.C. Higgins 12GA (583.16) bolt shotgun from the 50's. The stock mounting screwsis worn enough that the barrel/trigger pushes against the stock, so the trigger won't work. It could be esaily fixed, putting in wood filler, or silicone. Otherwises, it's a decent gun, but looks to be 60+ years old, although the trigger is a bit light.
Anyway, while searching for info, I found that these guns are subject to a Sears saftey recall, where the possibility that the bolt latch assembly can come loose and strike th operator.
According to the press release, if approved, I'd simply send in the bolt and get $160 and keep the rest of the gun, which of course would be inoperable.
Anyone know if this gun is of interest to collectors and therfore worth more than $160? It's realized, that this was a "cheap gun" to start with.
