Re: Is it probable that my engine is blown?
I just got back from the boat and pulled one of the spark plugs and it has a lot of water on it. I am taking that as a bad sign. I am not sure how the first one got hot but it was not from me running it too hard. The boat has a 6" cuddy in it and it is just not really built for speed. If anything, I drive it like a grand paw because I am so gun shy about the first time it blew up,,ha ha
Personally speaking,evey motor I`ve built from scratch or purchased as a short or long block get run on the stand 5 hours heat cycling so you dont get "micro-welding" of the rings.
volts, oil press, temp,leaks, noise,re-rightening,checking ,belts, everything untill I`m satisfied . Then I install it and take the boat for a spin, setting and adjusting what needs to be set.Then the timing is retarded just a hair and I safety wire the dist hold down bolt .Tell the customer to follow normal breakin procedures ,and call me in 20 hours to reset and check the timing.
some poeple want to see how fast a new motor goes and you cant do that untill it`s broken in.
What you could be doing is pulling the plugs checking for water, check the engine oil level and condition, maybe pull the starter and have it checked.
The heat tabs you mention are installed on the motor and if you exceed the normal temp ,they fall off. Easy to determine if the motor got hot at some point.
