bear_69cuda
- Oct 10, 2008
- 2,109
Morning gang,
So I?ve researched trim anode tab adjustment, and fully understand that if steering pulls to the left, the tab should be adjusted to the left (/) looking down facing prop. Water pressure should push the boat to the right counter acting left pull. But this doesn?t seem to help. My boat does this only at WOT with my stainless 14.25 x 17?P Stiletto advantage II. When I have my stock prop 14.25 x 21?P aluminum it does not pull to the left. When going to stainless prop I needed to change trim anode from stock style to this type.
http://www.iboats.com/Quicksilver_A...6066718--**********.903842687--view_id.166968
Do you think this tab would be less effective than stock type? It seems to have less surface area?
When cruising ~ 20-30 mph there is not much pull, but at WOT if I let go of wheel, the boat would be in a massive port spin?
Also I?m running smart tabs?.
1999 Alpha I gen II.
Any ideas or theories would be great!
Thanks!
Thanks!
