I need help! I'm a first time boat owner, and I have a question about a red valve that is mounted on the side of the motor near the carb. Should the valve be vertical or horizontal. I read in some other forums that it should be horizontal, but my motor will only run with it pointing vertically. I know the valve is involved in the gas flow, but what does it do? If it is turned the wrong way, can it be harmful running it like that? Any advice would be great!
