Wishin I was Fishin
- Jun 21, 2007
- 46
Good Morning to all!! I was finally getting to prime the aluminum blue fin last night. I had spent alot of time over the weekend sanding and sanding then sanding some more. Cleaned it all with the vinegar/water mix then let dry. Hit it with tack cloth next. So far I think I'm online here. Last night I primed with first coat of rustoleum aluminum primer. Rad the can well enough or so I thought. Sat back to admire my purely amateur paint job (ie: shabby) read the can again, to the last line this time. OMG!!! It says not recommended for water immersion!?!?!?!? what in the heck did I just do? So my question is this. Has anyone used this particular primer before and it ended up ok? or should I just bite the bullet and sand it all off again and start over. Oh and the reason why I used the primer to start with is I ended up with bare aluminum and deep scratches when I got frustrated with trying to heat gun the decals off. Grinders are great!!!!
