Mark42
- Oct 8, 2003
- 9,334
Re: MFG Gypsy 15 Tri-Hull Restore advice needed
You might want to cut larger holes, or more of them. Just to be on the safe side, a 4" hole saw would probably be the way to go.
I'm sure that eventually, some water will get in somewhere, somehow. It is inevitable. The good news is the polyurathne foam is what is used for floating decks and mooring balls, etc. So being in constant contact with water and still performing well bodes very well for the foam in your boat that will come in contact with very little water.
I read one test where a polyurathane foam block was weighted and sunk in 8 ft of water for months at a time. No measurable degredation of the foam was detected.
