nabularach
Banned
- May 18, 2008
- 52
I had my boat out in the bay and I drifted into a shallow area. When I noticed it I raised the motor and used it to push myself out into the channel.When I started getting up on plain the motor shut off.When I looked back there was smoke coming from the motor ( overheated and the warning buzzer didnt go off). I smelled a burning rubber type smell but when I pulled the lower unit to check the water pump it was blocked with sand but in good shape. I checked the compression (All 4 cylinders at about 110 psi)
I still have not gotten the lines cleared out, I cant get the screws for the thermostat cover loose so I am going to try heat and an impact driver. Does anyone know what the burning smell could have been??? Also I tried (With the lower unit off) Flushing the water tube with a pressure washer and I still couldnt get water to come through even after I ran the motor. Could there be anything else obstructing the water passage or maybe somthing that could have melted blocking the water passages?
