Does not want to idle at low speed, move throttle up it will run around 1500 to 1800 RPM.
I put the fingers in the throat of the top carb and she will run semi ok at idle.
Put the fingers in the bottom carb and acts like she is choking out. Everything points to the top carb being lean that I know of? I still have alot to learn though.
I cleaned rebuilt both carbs this morning, they are clean and all passage ways and venturi's, orfices clean. Deep Creep, carb cleaner,acetone and wd40 were used, wire through the bottom of the bowl jets, compressed air, everything is as it should be.
Compression is 120 on #'s 1, 2, and 3, #4 is 110, it had a bad head gasket so repleced it on 2 n 4.
Good spark checked with spark tester all 4 nice n blue.
On the v-4 there is a top carb and a bottom carb, do they have different jets? With the top carb being a little bigger for the fuel or maybe idle air jet smaller?
I think it may be I have two top carbs on this engine, of course part number tags are off so really cant tell what carbs they are. Thanks for the replies.
