MikDee
Banned
- Jun 6, 2007
- 4,745
Re: Newbie. Any words of advice?
Great Find! Good for you, normally I wouldn't worry about any stock cam, but If it's the 290hp/350, I might be a little concerned about overlap on the cam causing water inversion? This might not be an issue if you run thru-hull exhaust? I see It reaches 290hp at 5200rpm, so that's your goal in getting a prop to match, if using that cam. On a boat that old, the 1st thing I'd do is take the antisiphon valve (spring loaded ball check valve) off, and in tank filter, at the fuel tank, and make sure both are clean, and working properly, or replace the valve. Chances are it's got some gunk in it. Then make sure your fuel lines are are still good, & clean, up to your engine, I'm guessing you checked, or changed your fuel filters at the motor? and finally make sure your gas tank vent is clear. Good Luck, Mike
