Well i have notice engine will rev a bit hi before forward or reverse is selected , i have my shift interupt switch disconnected(i know it is a bad thing to do) but here is the technical part i only have a b+ and tach on my distributor , so i am wondering should i1.brake the ignition wire to the distributer bring it series through the Shift interupt switch of course removing the ground wire, or should i 2.just put a relay on by using the shift interupt switch as the ground for the relay and b+ open and close at relay terminals will there be enuff time response in engine dis engage ? i know this is a bit technical but thanks in advance.
