i'm having trouble starting 1975 evinrude 135 hp outboard when cold. The last 6 starts have taken anywhere between 30 secs and 30mins. Once the motor starts it runs fine and will restart easily. I used the boat for about 4 hours 2 weeks ago however couldn't get it started today. The starter motor seems to be working fine, the motor turns over but just won't start. The spark plugs were replaced about 5 weeks ago, the fuel/oil is good, the primer bulb fills ok, the battery is 6 months old and fully charged. Is it likely that i'm just flooding it and if so whats the best way to clear the excess fuel? or is there some other problem.
My normal starting procedure is to fill the primer bulb, put the warm up throttle leaver on full, and turn the key with the choke on.
I also noticed a few drops of fuel leaking from a T junction after the fuel filter but this only occurred when i got frustrated and squeezed the primer bulb a few too many times.
thanks
Matt
thanks
Matt
