Re: SUV manual suggestions...
Thanks for the replies. Alldata doesn't have enough detail, but they are great for diagnostics. Hadn't thought about GM, I'll check it. Of course there's always the option of the local library and a pile of quarters...
JCF, the AWD issue is a servo that engages the AWD on wheel slip. Fun part is you have to pull the front axle to change it. I read up on it and talked to 3 mechanics. It was the concensus that pulling the fuse would disable the 4wd, but not damage anything until I had time to pull it apart and replace it.
What I suspect from AllData is a TSB:
Subject:
No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts)
What a concept. Replace with more robust heat treated parts? What did they do, make the original part out of plastic?
