Re: Evinrude tilt/trim sticking
Take the voltage reading at the terminal(s) directly on the motor itself. <br /><br />If full voltage is present when actvated, yet no motor action till motor is tapped, suspect motor.<br /><br />If less than full battery voltage is present it still could be a shorting motor internally bringing the voltage down although it could be blowing any fuses. (bad motor, or dragging mechanicals within unit)<br /><br />Also if less than full battery voltage is present while activated trace backwards towards battery till full volatges are seen and suspect the last part that created the voltage drop.<br /><br />Although, first check motor housing ground to battery negative post (when energised)for any grounding differential that could also influance the issue.
