Caddiepmpn
- Jul 29, 2007
- 6
i bought an 89 renken 17' bowrider with an 85 johnson 150hp vro. this is the first boat i have owned and i love it but im haveing some problems. thanks is advance for any help.
problems:
1. fouling out plugs every time i go out. the gas is premix and i was told buy the guy i got the boat from that i need to put 1 cup of oil for every 5 gal of gas. does this sound right? also im using ngk plugs. is that ok for this motor?
2. for about the first ten min out on the lake the boat surges real bad. it will pull strong then lose power for a few sec. then pull good again with out touching the throttle. is this normal untill it warms up?
3. using the boat for wakeboarding. the motor will change speeds on it own when pulling. it will be fine for a min. then it will rev up and go faster on its own. if you bump the throtle down it goes way to slow. it olny does this while pulling. if im runing about 15-20mph with out the load its ok.
4. chargeing system. i put 2 new bateries in the boat when i got it. if i charge the bateries fully when i get home than it will run fine off of one most of the day but i will have to change to the second one after a while. also my tach doesnt work. i read somewhere that this may be related some how.
problems:
