Re: Fuel Problem '78 Evinrude, 35hp
In the very bottom of the carburetor, facing forward, is a hex head plug with a screwdriver slot in it. Take that out when the motor won't start. Gas should run out if there is any in the carburetor. If there is gas in there, it is not a supply problem.
Deep in the hole where the plug came out is the high speed jet. It is removed with a special screwdriver. Don't try to use a regular one, it will bugger up the jet and you may never get it out.
Use the special driver (see below) and take out the jet. It should be absolutely clean, not even a trace of gum or crud in it. If there is, you might get away with cleaning it, but more than likely need to disassemble the carb and do it right.
You can make your own special screwdriver. Use any cheap Wal-Mart type screwdriver with a 3/16" round shank. #1 Phillips screwdrivers are often ideal. Cut off the business end and grind or file a new flat blade with parallel sides. It is important that the sides be parallel. It is the tapered sides of a regular screwdriver that spread the jet and jam it in the threads.
