I have a 1964 evinrude 75hp v4 motor on my 17 foot boat. I was on the lake and the boat was not plaining out. I had alot of weight on the boat so I thought it might just be taking awhile to plain. The all of a sudden the motor shut down like someone hit a kill switch. I felt the motor and it was very hot. (Even the cover was too hot to touch for 2 seconds.) The boat starts and idles well. I have replaced the impeller even though the old one looked fine trying to fix the overheating. I took it on the lake again and it did the same thing.
On the v4 75hp this is two tubes coming from the head to a housing that contains a single vernatherm control. I removed the two hoses coming from the head to see how much water flow was coming out. Looking from the back of the motor where the spark plugs are the left side has a full stream of water shooting out and only water. On the right side there is some water and it looks like alot of exhaust. It is the white smoke that is normal coming from the exhaust but should it be coming from this water outlet also? From running it in a trash can with the tubes off it feels like the side with the exhaust coming out of it too is alot hotter than the other side.
Is it normal for exhaust to be coming out with the water on only the one side and not the other? What could be causing this to happen? Please give me ideas on how to fix it. The impeller was installed correctly and so was the water pipes as one is short than the other and its impossible to mix them up. Thanks for any help you can provide.
Steve
Steve
