Re: Skyline 21 gallon fuel tank
Here is a picture of the fuel tank:
it is a Skyline, manufactured Nov 3, 2000, 21 gallon, model 30023-04, material is XLPE. There are two wires, a black and red, leading under the deck somewhere...they are going under the deck where the battery sits. I am not really wanting to tear up that deck but I will if I have to. Do you by chance know if that is going to lead to the "sending unit?"
Here are some pics, not good but you can see:
The red and black wires there are going under that little deck plate under the battery. The other wires are all going to the battery terminals.
These two ports have no wires to them, They cannot be the sending unit. I removed the one on the right :shrug: there is nothing there. (maybe a little gauge is available to insert here to show fuel levels? do you know of such a thing?)
I took out that little deck there under the battery, but it does not want to come up unless I:
remove the carpeted vertical face to the battery compartment.
The red and black wires go under the deck there...those other ports have no wires attached to them. Do you think those wires lead to the sending unit? I can't find this tank diagram online. Seems Skyline is no longer in Utah. If I had a drawing of the tank I could determine just how much of the deck I have to take up. Any ideas? to find the drawings?
If I knew where the sending unit was, I could save a lot of work taking up unnecessary deck. If it is far forward from this face, this carpeted vertical face enclosing the battery compartment, I'd only have to remove the chairs, maybe that little deck box up forward and the biggest length of deck plate up the center. This carpeted face running vertical is on very tight. Its a very tight fit across there and I am hesitant to remove it. Any ideas where it could be?
Also, trying to sort out the wires under the dash from the fuel gauge will entail a lot of snipping of wire ties. I am not sure I want to go that route yet either.
Thanks,
Cleo
