Hi.
Any one have any idea why the bilge would constantly fill with water? The boat is a new 2012 FM165 and the manual does say a little water is normal. But this is hardly normal. If the boat is left in the water overnight as was the case this weekend, the entire bilge is under water. Used the bilge pump to pump this out, then while on the water all day, you can see the bilge again taking on water.
Any suggestions as to where i could start solving this?
Thanks in advance
Dave
Thanks in advance
Dave
