xXTJTHEBOATER95Xx
- May 19, 2012
- 56
I have a shurflow pump for my raw water washdown. I havent installed it because I just bought the boat so it is new to me. The pump makes a sound like its pumping but water doesnt discharge.
It is connected to a through hull fitting in which the livewell pump is also connected. This will fill up, but i think its because it's using a different pump.
pump is properly mounted above the water line and the website says that it is self priming to 6 ft. above the waterline.
Is there something I can do to test it before I have to open it up?
Thanks for any help!!
