Hello and thanks in advance for your time and help.
I've got an '89 VIP with the 140hp inboard GM 4/cyl engine. The problem which started late last summer:
Put it in the water, it starts/runs fine. Has a LITTLE hesitation upon throttle, but works.
After approx. 20 minutes or more of running both high and low speed, it will not accept any throttle to accelerate from idle, simply comes off idle, sputters and dies.
From idle, no matter what you do it'll die. Slow feed of throttle or jam it, sputter, sputter, dead.
At first signs of trouble it will idle fine while not in gear, only die when you put it in gear, then it gets to where you have to give it throttle just to start it, drop it back to neutral, and then TRY putting in gear, only for it to die again.
As I said, it started this last outing last year.
I Just rebuilt the carburetor with new accelerator pump, the whole works, new alternator, filled it with new premium gas and Sea Foam, replaced and gapped the points, checked the 2 year old spark plugs which still look new, and last year I once again replaced the ignition coil and and added an external resistor (it seems to burn up coils...).
HELP PLEASE?!?
THanks, Steve W.
HELP PLEASE?!?
THanks, Steve W.
