Quicksilver throttle
DGH23
1-1-2013 033.jpg1-1-2013 032.jpgI have a 1988 Pro-Line. The neutral push button on the throttle is broken. Its a Quicksilver and i'm trying to find model number etc... for it. No luck. Any help with parts,diagrams etc... is appreciated. Thanks
Don S
Re: Quicksilver throttle
Post a picture of your control.
Too many different ones to guess what you have, especially if it's been replaced.
four winns 214
Common problem on the Commander 3000. In fact, I'm having my 80s Commander 3000 replaced with a current model because of a balky throttle-only button. But, the only way we'll be able to help you identify your exact model is with a photo of your installation.
Texasmark
I threw my Quicksilver (Merc) model 3000 in the trash for the same reason. Now I have a 2000 butttttt it mounts on the outside with the cables visible and you may not want that on your Proline. I wanted the exposed fast idle that the 2000 gives you. I wouldn't rebuild one as on mine the insides were ALL worn out anyway. Just get another I guess.
Mark
DGH23
Mark
Here's a couple pix of my control.
Texasmark
Well that's neither I mentioned. If it's not on the site look at west marine. They show several similar Teleflex units. since TF makes the cables just seems a natural extension to make the upper cut controls too. Hang onto your wallet.
Mark
Don S
Here is the manual for that control
These pictures will show you the neutral only parts (#27) you just need to figure out if you have 28 or 28A
