Hello ALL, I am a marine tech and new to the forum..
I currently have a 1987 Yamaha 150 that is baffling me..
It is starving for fuel at top end after about 2 minutes of run time.. only at high rpm.
it does run perfect within two minutes or so then it starts starving. i can prime the bulb and it will catch back up.
i have already changed, primer bulb, cleaned and rebuilt carbs, changed fuel/water separator, pumped tank, changed fuel line, and also changed fuel pump. i am at losses on this one and need you guys's help here.
more info on the pump. i only got one.. all we had in stock so i threw it on the top.. didnt change anything.. so i switched it to the bottom.. still no change..
could of both pumps went bad? is that common?
if you need to know anymore info let me know.. if anyone can give me some help ASAP..
trying to get this customer back on the water..
Thanks you all again.
