stiffneckrob
- Sep 20, 2008
- 3
Bought a used motor, seems to start, idle and run strong. There is a ticking noise coming from the engine area when at mid throttle and higher. It's not horrible, but then again doesn't sound normal. Would it be the valve adjustments or something else more common to look for?
Lastly, the plastic bushings are worn out of the tilt/trim pivot rod at the transom allowing the motor to move around on the shaft. I have the bushings. Is it a time consuming job to replace these?
Thanks in advance!
Rob
Thanks in advance!
Rob
