I've got a 2000 DF 70, with 650hrs. The engine has been maintained religiously, nor has it ever given me any problems.
The oil leak is not really enough to lower the level on the dipstick between runs (4hrs) but it will leave a "slick" on the water. The oil is more apparent after trailoring it back home, in a full forward tilt position.
I've cleaned the mess all off & ran it all day @ idle with the "muffs" on all day @ my shop with no signs of leakage. I thought maybe it would only leak while tilted up, so I cleaned it all off again...let it sit all week & still no signs of leaking.
I put dye in it & checked the oil filter, Oil pressure switch, valve cover gasket, etc. Still no signs of leakage until I ran it in the water & trailored it home. I checked the crankcase vent hose from the valve cover to the air intake & it is DRY.
So far All I can really determine is that the oil seems to be the heaviest near the air box to throttle body connection.
Any Ideas????, Thanks in Advance...Elliot
