GilligansIsland
- Apr 14, 2010
- 138
I am replacing my '97 Volvo 7.4 GL and would like to add a Full closed cooling system. I know Volvo does not offer this as OEM, but I thought, "hey, why not?". Here are some details that may help solve this:
The boat is an '85 Contessa Command bridge
The boat is fitted with through hull exhaust so Y Pipe alignment will not be an issue
The boat is also fitted with a through hull raw water intake (not using the drive leg. don't know if that matters)
I will buy a "universal" manifold/riser set from Barr that has the proper porting
I will be buying my closed cooling system from San Juan Engineering of the proper size
I will be buying the New Long Block from Doug Russell, (who will deal with SJE and send the entire package)
My original alternator was mounted high (like OMC), but I'm sure another bracket could be used to set it low
So, there ya go. I can't imagine I am the first one attempting to put a fully enclosed system on a Volvo and hope you guys can steer me in the right direction.
Thanks in advance.
Thanks in advance.
