I am having an ongoing issue since I took the boat out this summer. When the boat has a load it will run "fine" up to about 2200-2500 rpms. If I try to push past it the engine slowly bogs down until i come back a bit on the throttle. I took apart the carb and cleaned the jets. Fresh fuel. Bought new plugs and gapped them to spec.
I bought a spark tester and at the recommended gap I am getting a spark (when it gets darker out I will verify that its a good spark and not a weak one) I then set the gap to just about a half inch or less to see the spark strength. It wasn't sparking at all. Not sure if it would or not at this distance?? If I close the gap a little more then it would spark once in awhile.
I also tested the resistance of the ignition coil. I believe the primary winding measured 3.2 ohms and the secondary winding measured 9.94 ohms.. I am not sure what the factory resistance should be in this particular ignition coil. If anyone knows that would be great! Or if someone could provide the manual that would have this information. I have a service manual but it doesn't have anything in it about the ignition coil specs.
If anyone else has any other ideas that would be greatly appreciated.
Thanks,
Cory
Thanks,
Cory
