Hello Everyone.
I replaced the spark plugs, Replaced the gas filter, and oil filter. Then did a oil change on the engine and checked all the connections and as half assed as the pervious owner left them I cleaned them up taped them for future cleanup. I got the enging to turn over now but no fire. I checked the spark plugs and no spark.. So I got down to the coil which is a BOSCH 0221122006 COIL. I not sure how to test it but I unplugged the main cable that ran to the distributor and got a friend to turn the key and I held the cable near ground.. NO SPARK.. Tested with a light and multimeter and I had 12v to the + side of the coil. I did read somewhere that you could test the coil but you would need to know the resistance so it can be measured on a multi meter.
Anything else I should do ?? Different ways of testing etc ??
P.S. HAPPY EASTER!!
P.S. HAPPY EASTER!!
