Re: Volvo 260 ENGINE W/280 OUTDRIVE
7505scron, like bond-o, i'd start with the basics. I also have the same combo engine and drive but i have two of them. I have been learning a lot about them over the past two years. My boat, i believe, sat for a couple of years before i got it. I have been slowly working on different pieces and each time, the engines run better. I priced the carbs for giggles and they are not cheap. You can't buy them new, at least i did not find any new ones and rebuilt ones were $400-900. I'd start with the ignition system (points, condenser, plugs, wires, cap, rotor) and retime it, also check the inline fuel filter. Then rebuild the carbs if there are still problem.
