Volvo DP-SM U-joint cross reference
moonshn
Was wondering if anyone knows of the equivalent Spicer u-joints for a VP DP-SM drive?
From what I understand Volvo does not sell just the joints anymore, but makes you buy the whole shaft.
After driving a Jeep Wrangler with 7" of suspension lift with a ~1' long rear driveshaft I am very used to pressing in new joints and was hoping I could pick some up at Napa for a lot less $$$ than the new shaft.
This is on a '99 and has the c-clips on the inside of the yoke.
Thanks,
Alan
moonshn
Re: Volvo DP-SM U-joint cross reference
Are these the same as the precision 344's used in the Merc drives?
moonshn
Update: The Precision 344's have the c-clip on the outisde of the yoke.
The great guy at my local NAPA broke out the micrometers and came up with NAPA part number P317 that should fit:
Got them installed and greased with no problems. Cranked her up on the muffs and cut the wheel lock to lock with no vibrations. Will report back after a sea test.
-Alan
p.s. $25 for the pair of them :D
Ayuh,... Alittle late now, but that Info is available up in the Adults Only section of this forum...
moonshn
I saw the post there regarding the Merc u-joints but none for the Volvo's.
Then I found this thread about the Volvo joints with the c-clips outside the yoke, but mine were different.
-Alan
