I have an Eska 1980 9.9 HP outbd (11452A) that stops running when carb bowl empties after being primed from the tank hand bulb. I have to keep squeezing the tank bulb to keep it running. I have run fuel line with new squeeze bulb directly to a different bottle of mixed gas directly from the carb bypassing any in-line quick disconnect fittings. I have rebuilt the carburator, including the orange filter element ensuring it is positioned at the 2-8 position. I have used a new mounting gasket and made sure the flapper valve gasket was hitting on flat surfaces when I had the carb apart and that all passages were clear. The float seat and needle were replaced and float is level when carb is turned upside down ensuring that the needle seat is securely pushed all the way down in it's hole. Plugs have been replaced.
I can only make the engine run if the fuel tank is at same height as carb. I suspect that the pulse coming from the crankshaft is too weak to make the flapper valves work effectively. Has anyone found a way to measure it with holding a rubber tipped gauge on the hole while pulling the cord? Also what compression should I get from the cylinders? This motor has seen very little use and it hard to think that the crankcase gasket is bad or engine has internal wear. Has anyone found an after market carb or a perhaps experimented with a primer for the gas tank to push the fuel to the carb? I have read a lot of the forums and most suggest throwing this one and be rid of it. It still looks new. I acquired it with the Jon boat.
