Re: Firestone 7.5 hp please help identify year maker etc please
Welcome to the iboats.com forum. The members here are great and the experts, which I am not, can help you solve any problem. I believe you have a motor built for Firestone by Scott. It looks like a 1950's era Scott to me and I found some info online that seems to confirm that. Your stock number COULD be 10-A-103 instead of 102 which appears to be a 1955 model. The 133xxxxx code cross-references to a 1959 model. Maybe one of the gurus will jump in here and explain it to both of us!
The link below will get you to a free online public library that has lots of manuals saved in pdf format. They have one that covers your motor. While it is not a "factory" manual, it does have information that you might find helpful to perform routine maintenance items and maybe even some heavier maintenance.
http://forums.iboats.com/showthread.php?t=393281
LOGIN as directed and then drill down to: Small Engine, Marine/Boat Motors, McCulloch, Scott 7-1/2 HP (1955-1959) and Condensed Service Data. There is a Firestone file also with some model number data under the Parts procurement header.
Good luck with that great old motor!
