andy nagel
- Jan 20, 2012
- 4
i have a 1993 4.3 yamaha that runs great in straight line, but stumbles during turns. it has a rochester 4 bll which has been rebuilt. i hooked a six gallon tank into fuel line eliminating my tank on boat and motor responded the same way. it will run great at wot until you turn the boat either direction. i ran 22 miles down the lake and it did not miss a beat until i turned and then it started bauging down. i can pull back the throttle and open it up again and it will immediatly come back to life. it almost acts the same as when i had the water pump(impellor)going bad- like it is in a limp mode, but an alarm would go off then and there is no alarm with this issue. engine starts and runs great until you turn. any help would be appreciated.
