50.00 non running and may be 150.00 if it is running.
Good valuation for a "used" motor.
If it were truly "new" and could be documented with the original owner's manual and original hang tags, $1000 would be a minimum to a serious collector. If it were an OMC or a Merc, double that.
I will look into manual but Hang tag would be the info tags on the motor correct? Thanks
