SeaKaye12
- Jul 3, 2005
- 1,107
Hello all....
I know that there are plans and pictures all over i-boats of engine stands....and cut-away plastic/steel barrels .....but I was hoping to see some examples of combinations that work well.
Here's what I want:
(1) I tinker with older (40's-60's) motors up to....say....35 HP. Some of them; especially the older 25's and 35's ARE A BEAR TO PULL OVER. I need a stand that will stay put.
(2) I have access to a steel 55 gallon drum....so I figure I would use that as the "tank".
(3) So....I would like to build a wooden stand in an "L" shape.....and have the 55 gallon drum rest on the bottom of the "L".....there-by weighting it down and preventing the entire thing to move around when the engine is pull-started.
(4) I would just like to see how any of you have assembled this.....the size of the lumber and how you've put it together in a way that lasts and is strong.
OK?
Here's what I want:
OK?
