ok, the first pics are of the outdrive on my family's old boat. I grew up on this boat and plan to update/restore it. I got the ok from my mom so it will likely be my winter project this year. I know both are mercruiser but I have no idea what the engines actually are and my grandpa has developed altzheimers (sp?) and is now clueless.
I can tell you that the second outdrive shots are of a boat that was bought for the spare outdrive and because the water housing on it was intact and was going to be used on the family's boat (as you can see it is missing on that engine).
both engines and outdrives ran as of 2004 but the points are now toast on both...easy fix.
I'm wondering what the engines are exactly and what the outdrives are exactly and what you think I can get by parting them out?
I'm looking to convert the family boat over to a 350 I/O setup as we have an old speedboat with a complete setup for it and I have spare running 350's. I posted a thread a while back to ID the setup which everyone stated is an unreliable OMC cobra setup. basically, what I'm wanting to do is use that speedboat setup to get the transom/stringers setup to accept a 350. then part out both the old 4-banger/mercruiser setups and converter the outdrive for the 350 setup from the OMC cobra to an alpha-1 outdrive using the money from the 4-banger setups to purchase the alpha-1.
main reason is I've read parts are more readily available/cheaper for the alpha-1. or should I just part the 4-banger setups out and use the cash to rebuild the OMC outdrive after fitting it to the family boat? I'm to suggestions but regardless the 4-banger is coming out and the 350 is going in. much more reliable setup compared to the 4-banger. I have too many memories of it breaking down and we'd have to get towed in or grandpa would try to rig the points, etc on it.
I can fix a 350/HEI setup in my sleep...and the extra power will be nice too.
here's the link to the OMC setup thread:
http://forums.iboats.com/showthread.php?t=457969
pics of the 4-banger setups:
Family boat:
donor boat:
Family boat:
donor boat:
