Please attach a diagram file if you have one thank you my motor won't spark
A appleo Petty Officer 1st Class Joined Jul 19, 2012 Messages 388 Jun 9, 2013 #1 Please attach a diagram file if you have one thank you my motor won't spark
r.j.dawg Ensign Joined May 30, 2011 Messages 993 Jun 9, 2013 #2 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you Everything you need should be right here. http://forums.iboats.com/mercury-mariner-outboards/faq-mercury-mariner-outboards-459535.html
L Laddies Banned Joined Sep 10, 2004 Messages 12,218 Jun 9, 2013 #3 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you
A appleo Petty Officer 1st Class Joined Jul 19, 2012 Messages 388 Jun 9, 2013 #4 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you Laddies said: Click to expand... Thanks. Are the trigger and stator seperate items? My trigger outputs all read 18k ohm a to ground I pulled my stator they appeared to be one unit?
L Laddies Banned Joined Sep 10, 2004 Messages 12,218 Jun 9, 2013 #5 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you No, the trigger is held in place by the stator which is held in place by 4 screws on the top main bearing cap
A appleo Petty Officer 1st Class Joined Jul 19, 2012 Messages 388 Jun 9, 2013 #6 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you Laddies said: No, the trigger is held in place by the stator which is held in place by 4 screws on the top main bearing cap Click to expand... Ok I will pull the flywheel again. Will the trigger be on the bottom of the stator.... Is the trigger screwed into the stator?
L Laddies Banned Joined Sep 10, 2004 Messages 12,218 Jun 9, 2013 #7 Re: Help. Seeking wiring diagram 1985 50hp mercury 4 cylinders thank you The trigger should be just setting inside and under the stator and it has to be able to move back and forth to advance and retard the timing
