jcochrane281
- Oct 31, 2012
- 25
There has been a lot of post on this engine and I want to make sure I'm just replacing what I need to this 90hp has the red stator and when I ohm the green/white and the white/green I get nothing ohm them together or to ground nothing I am getting good numbers off my trigger and not to sure on checking the switch bow BUT on my two yellow wires where they connect to the other yellows going to the regulator the plastic water proof covering is slightly melted and discolored could the reg be bad and caused the stator to fail as well thank you for taking the time to read this post and any pointers or advise is a plus!
