circle hook
- Dec 6, 2007
- 271
I have a 1996 mercury 225 HP offshore motor and she will run at idle to around 1500RPM and if you can get the motor up to 2500 RPM with out stalling she will run fine all the way to 4800 RPM @ 32 KTS, The fuel system is completely brand new from the filler caps & hoses, fuel lines to the racor water filter, right up to the carb's. she had a tune up and ran in a drum, she ran fine but under load between 1,500 and 2,500 RPM she will stall, any one ever have this same problem.
