Stator Question
I'm new to the forum and don't know how to start a new topic so I figured I start here...
We have a 2001 Mercury 200 CXL outboard ser number is 0T391198
We now have a no start situation .... Ran rough at idle ... Fine at top end...then started stalling while running... After it was warmed up....Fuel system all good....lead to electrical ... Have spark at all coil packs...trigger tests out good....but resistance test on stator is 441 ohms ...cranking 168volts using DVA ....can't get a running test as it won't run....if I'm correct the ohms should be 660 to 710 which leads me to be leave it's the stator .... But can't confirm it as I can do a running test.....which in the Service Manuel says running the number should be >200.
Options ??? Stator on the boat is $500 so don't want to guess
Thanks
Capt Mike Mas
Thanks
Capt Mike Mas
