delasem
- Feb 5, 2008
- 22
Hey everyone,
Hope you can help with this one?
Let me give you the technical stuff first:
Caravelle 1999 BR, 5.7 Mercury Magnum. The carb is a Rochester quadrajet 4 brl NEW.
Installed the carb yesterday and took the boat for a spin, my idle issue is gone and I now can shift without the engine stalling, the previous carb had the idle circuit damaged.
Here is my new dilemma, boat takes off great and has a very fast level trim take off, like a dream. Engine sounds strong and it pushes this bad boy nicelly until RPM gets to 3200, all of a sudden the engine falls to about 3000RPM than within seconds and without me touching the throttle it rev's back up to 3200 and back to 3000 and back to 3200...you get the point. What the heck is going on?
The boat has had a full tune up two weeks ago that included the plugs, wires, rotor, distributor cap, magnetic timing sensor, PBC, coil and fuel pump, during this time we did the timing and it is at 8 degrees as per the manufacturer specifications.
The touchy thing I did not do was touch the carb, out of the box it went on to the engine and no tuning was done. This was because it started fine and idles great so I figure why mess with it.
Here is the kicker as long as I don't rev the engine over 3200Rpm the boat runs and sounds great, better than ever.
Can anyone point me in the right direction with this problem?
Thank you
Thank you
