Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
4.3 liter mercruiser- no oil pressure showing at gauge
  • 4.3 liter mercruiser- no oil pressure showing at gauge
    Just changed oil in my 1999 4.3 liter mercruiser with Mobile 1 10-30 synthetic and a K&N oil filter. Showed good oil pressure when I warmed up the engine before the oil change and now that I have new oil and filter on and started the engine for initial warmup period it show's no oil pressure at the gauge. Engine sounds fine and oil level is up. Not sure if there may be goop in the sending unit or ?????????. Changed oil in a lot of engines and never had one not return oil pressure to the gauge. Scratching my head. Any ideas?
    Re: 4.3 liter mercruiser- no oil pressure showing at gauge
    Ayuh,... Welcome Aboard,... probably be coincidence...
    Ground the sensor wire,+ see if the gauge pegs,...
    Plumb in a mechanical gauge,...
    • #3
      verify with mechanical gauge before you do anything, don't want to risk the engine.
      • #4
        Plumbed in mechanical gauge. No pressure. Coincidence that my oil pump takes a dump between an oil change??? Strange. Also tried grounding the wire to the electric gauge and it does not seem to max peg. I suppose this 4.3 has the mechanical oil pump located inside the pan! Just my luck.
        • #5
          if you have no pressure the valve lifters should be clacking away.
          • #6
            zero oil pressure = pullin' the engine. pretty common for the pickup tube to drop into the pan.
            • #7
              Crazy luck. I actually tried 3 different mechanical gauges and got no pressure from any of them but I noticed nice clean oil on the tip of the threaded part of the gauge when I pulled them out, so I figured I would turn the engine over to see if I actually had any oil at that point, when I did it there was some oil but not a lot until I pulled the cap off of the filler tube. I reinstalled the mechanical gauge and sure enough I have pressure again. Put the sending unit back on and my dash gauge is back to normal also. All I can figure is that by using the siphon type oil change through the dipsitck tube that I created an air lock in the system somewhere. Wow! sure glad I don't need to pull the engine! Thanks for you input and ideas. Sometimes it's good to walk away from the problem for awhile and talk to somebody rather than beating yourself up over it and overthinking. Ice is off the lakes, I'm goin' boatin!!
              • #8
                That shouldn't be possible.
                Don S.
                Please, no PM's (Private Messages) regarding boat/engine problems.
                That is what the forums are for.
                Only forum/moderator issues will be answered in PM's.
                • #9
                  .... All I can figure is that by using the siphon type oil change through the dipsitck tube that I created an air lock in the system somewhere. ....
                  Nope... Crankcase is externally vented... Can't pull a vacuum inside (or anything close to that)... This DOES NOT make sense.
                  Maybe a bit of crud in the sender hole that got blown out when you ran the engine with nothing in the hole?
                  Glad you're all fixed.
                  Chris.........
                  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                  The world takes on a whole new perspective when viewed from 100’ below.
                  1972 Bertram ‘Bahia Mar’ 20
                  2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
                  (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
                  • #10
                    Originally posted by don s View Post
                    that shouldn't be possible.
                    Snap!!!
